AN Fittings and oil cooler lines-where local?
got2boostit2
Need to buy AN fittings and lines locally. Any sources on the west side? Livonia, Farmington, Dearborn, Canton, Ypsilanti area. Can't wait for Summit, they shipped slow on most recent order.
You will have to make a road trip, but there is an Earl's shop on 14mile between Gratiot and Kelly Rd. Someone will have to chime in with the exact name of the place, but they will most certainly have everything you are after on the shelf. I want to call the place Fluid Systems??
Think that's it.
What fittings are you looking for? I have 4 of each of these new in the package that I could have out quickly. I can also order about any you need from my MI supplier. Typically next day delivery here in MI.
FBM1014 -10AN Straight
FBM4023 -8AN 45° elbow
Pulling lines Thursday evening, believe the lines are 1/2 ID. But don't know it/what bend fittings I need ATM. Trying to see if I can source parts Friday to remake engine oil cooler lines. Thanks for the fast response.
i've bought here before too, they even stock the ano-tuff (black ones). Mazza Auto Parts carries AN fittings too but just the red and blue ones.
Fluid Systems Engineering has very competitive prices with Summit too. Sometimes even marginally cheaper than Summit.
Associated parts on 8 mile just east of Orchard Lake can make up hoses on the spot. I've used them for fuel and trans cooler lines. They have hose suitable for both fluids. They usually make them in JIC, the steel equivalent to AN. They outsource brake lines locally, but turned around a double banjo brake line for me in a couple hours.
X2 on the Parker store at Exotic Automation. I used them to fix my 5/8" Tranny cooler lines on my Dmax. Turn in between the pond and the HD dealer.
