Almost complete 1990 5.0 engine - Core or clean up and use as is
2MANYMUSTANGS
I have a 5.0 engine that I am pulling out of one of my foxes. It is basically stock. The engine runs well and you can hear it before you buy it. It has 100,000 miles on it. The only issue it has is some oxidation or a build of of some kind in the water passages. I was going to flush it and run it as-is but decided to build a new engine instead. For the most part it will be a complete engine. I only need the distributer, a couple sensors, and maybe the fuel lines. Otherwise it will be complete pan to throttle body. I will post some pics tonight.
300 OBO. Send me a PM if you are interested.
I am in Oxford - About 10 miles north of the Palace of Auburn Hills. The engine is still in the car and you can hear it run. Can also do a compression test as well. My plan is to pull it this weekend or sooner if I sell it. PM me if you are interested.
I am replacing the engine with a high performance small block that I built. I am using all of the accessory brackets, the distributer, and a few sensors. Everything else is there. I had the engine running yesterday and will upload a video later today. I will probably be pulling this engine tomorrow.
Are all the a acc and brackets on it
