FAST93
Moving to Mechanical Fuel Injection so I don't need this any more.
Ran for 1 season. Pump is in great shape and will work with either alcohol or gas.
$250.00
ULTRA 350 FUEL PUMP FEATURES:
Flows Over 350 GPH
Designed for Engines up to 850HP
Billet Aluminum Housing
Billet Aluminum Mounting Bracket
Hard Coat Anodized Billet Aluminum Impeller for Long Life
Bright Machined Finish
Replaceable Delrin Wear Ring
External Line Pressure Adjustment
Can Be Adjusted While Running With No Fuel Mess
Line Pressure Range is Adjustable From 14~25 PSI
High Carbon Brushes For long Life, Low Amp Draw and High Torque
Draws Only 9.5 Amps
Double Lip High Performance Shaft Seal
Every Pump is Tested for Flow, Pressure and Leaks Before it Leaves Our Facility
100% Made in U.S.A.
$250.00
Flows Over 350 GPH
Draws Only 9.5 Amps
100% Made in U.S.A.
