It realy doesnt, specially on an alignment rack. Do a four corner alignment and get the thrust angle right, and then center the rear in teh car with the upper. If everything is installed properly you can usually adjust the uppers by hand, do it half turn at a time bounce car check centerline. Dave does this with measurements, and can probly do it in his sleep now. The lowers aren't as bad as they sound either. Just drop one at a time with a jack under the arm, lower it out of the torque box make your adjustment and jack it back up. Might need a pry bar or something to help get the lower back in but it's not that hard really. I did mine in my driveway with tape measures, and i've been low 1.4x in teh 60 and never had to steer the car.
Most things like this sound intimidating untill you just get under the car and do it.
