turbo89gt said:Most likely one of your wheel speed sensors. :icon_mrgr
turbo89gt said:That is something that will be hard to find possibally. It may have to be taken to a dealer and hooked up to the scan tool. I would do a visual in all of them and the wires and plugs. I would as well check your brake fluid and your ABS modual. If nothing abnormal is found its possiablly something in the ABS computer or a failed sensor, in which it would need to be scanned to find out exactly what is wrong.
hatchback said:ABS SUCKS disable it before its to late!
1BADAIR said:did you have the recall done to that truck
not scared just dont like things that take a shit! which is everything modern i guess!orangejuiced86 said:Why are you so scared of technology? Just curious thats all. Not a flame by any means.
braxx said:I have a 2000 F150 2wd and my ABS light was on. I checked it with my scan tool and it was a code for the rear sensor (In the diff., not at the wheels). I erased the code and it came back as soon as the truck moved 5 ft in drive. I bought a new sensor, put it in and all has been fine.
Josh
82hatch said:Cool, thanks for the tip. Now to find someone w/ a scanner I can use...:lol:
not ABS codes91Notch said:I think they can scan it at autozone for you![]()
dave89iroc said:not ABS codes
