RSpencer
This is on a 99 Ram 2500 4x4 Cummins. I changed the pads and rotors on my truck. As soon as I started it up, the ABS and brake light were on on my dash.I got a code 71 and 73, the 73 went away. I was told it could be from pushing the piston in without cracking the bleeder screw on the caliper, and the dirty fluid went up into the modulator causing a piston to stick in it. Anyone ever have a problem like this? The pump motor also doesn't reset itself like it used to when I turn the key on. I had to remove the wheel speed sensor connector from the hub to get the rotor off, I don't know if that would cause an issue, but I don't see why.
