fastredgmc
never mind low oil pressure problem ended up being a bad sending unit. you guys all lost out on a sweet deal. Ill relist it for alot more when it all fixed
94 Trans Am
lt1 auto trans
non leaking T tops
newer trans 20k ago shifts perfect
car is all stock with 140k miles on it.
I bought it a month ago not running. I put a new MSD cap and rotor kit on it and new plugs along with a oil change and new coolant.
car runs and drives but just dont run like it should and the oil pressure gets low when its warmed up might need a engine or maybe just a fualty guage i havent looked into it. the engine has no ticks or no knocks at all.
Body is clean only issue is some rust behind the drivers door toward the bottom and it needs new door pins on the drivers door. under carriage is spot less.
inside is very clean
car was very well taken care of I have every reciept for everthing ever done to it most work done at the Dealer I added it up and there is just over $10k in Reciepts.
car is perfect canidate for a buildup
I dont really have to sell it but dont know when i can get around to fixing it. Im asking $2000 if I cant get near that ill just find the time and fix it.
I have some pics i can email if anyone is interested
please post pics94 Trans Am
lt1 auto trans
non leaking T tops
please post pics
Hey i made this account just to ask you for your number so plz do so thx
