84 Capri / Built LS1 swap
v8killr4u
I purchased this car from a board member here a few months ago. I have a new toy now and looking to make some space. I'm pretty much selling this for what I have into it. If you do not have the cash, please don’t waste your time or mine. More Pics can be seen on autotrader, just search for 84 capri in zip code 48038. $3900 Firm.
Motor
Stock Block LS1
Stock Crank
.010 bore
Lunati Pro Mod I beam rods
Mahle Pistons
CNC ported 241 Casting heads
Compression 10.5:1
LS6 Intake
Small Cam (Not sure on the size)
Headers
Flow Master Mufflers
Transmission
Roller Turbo 400 with manual reverse VB, with trans brake built by Mike Riding (MI) (recently freshened)
Converter (fresh) 4800 stall on spray, 3000 on motor by Mike riding (MI)
Rear End
8.8 rear end with 3.71 gear,
Strange axles
Spool
Suspension
Double adjustable uppers
Single adjustable lowers
Welded frame ties
New Rubber, new door molding and seals
Misc.
New Red paint job (Looks real good)
Twin 255l in tank pumps, rear mount filter and rear mount return style regulator
Battery relocated in the hatch in Morosso Battery Box
What did you get. I wanted to see you get this thing tuned, the kit installed an run this bitch at the track. This setup is mid nines on spray.
I know man, Got the GN back and no time to do what i want to do. I really dont want to get rid of it.....I would love to put this drive train in a G body and have a nice lil street car.........Damn I might keep it. To nice of a car with alot nice parts.
Good luck on the sale
I can say that this is a clean roller solid floors solid torque boxes,solid frame rails would make a nice cruiser,man I miss this car
