8.8 Rear - $100 takes it!
phattpat
New member
8.8 rear, open diff. No tag on rear, I haven't gotten around to figuring out the ratio. Drum brakes, original leaf spring mounts. I believe this is out of a Ranger or Explorer, measures approx 58" wheel mounting surface to wheel mounting surface. Brake parts were in pretty good shape last time I checked (a while ago). Recent black paint job, not at all dirty and grungy. $100 takes it!
No idea... I'd have to go take a look. I believe, though, that the center section is pretty much centered, if that makes any difference...
Last bump, with pics... Has a u-joint type driveshaft coupler, not a later model flanged type. I also have a new pair of leaf spring mounts, if needed to relocate these. Thanks!
