60 gallon 2-stage 5HP air compressor (needs new motor)
Ozz
I was going to scrap this thing but was urged to offer it up for someone who may want to fix it or use it as a spare tank. The motor is dead and has been removed. I still have it in case anyone takes this and would like to try to repair it, scrap it, or whatever.
It was purchased about 4-5 years ago from Harbor Freight and used heavily daily for a long time. It's very powerful and was used for constant media blasting. I have an old belt as well, but it should be replaced. This will get you up and running but a new one is necessary sooner rather than later. I can point you in the right direction to get one online (as well as a new motor if need be). The pump is still fine as far as I know. Before the motor finally conked out this thing was still pushing tons of air once it got going. Then one day, pfffffffft! There goes the motor.
If interested, make an offer. It's just going to get scrapped otherwise. I'm located in Canton and can help load, but I can't deliver. If you need, I could help unload too if you're not too far away. I'll entertain trades if anyone has anything in mind. I just have to get this thing outta my garage because summer is coming and I will need room!
Specs:
Air delivery: 13.5 CFM @ 165 PSI, 15.8 CFM @ 90 PSI, 16.4 CFM @ 40 PSI
Cast-iron cylinders and stainless steel valves
ASME tank with safety valve
No mag starter required
