5 lug conversion................
bigg
on a 87 4 cyl car (mustang), what is the cheapest way to go 5 lug on the front?
i herd use ranger rotors?
tell me what will work
( not my car by the way)
The way my dad did it was he took the axles and plugged all of the wholes and programed the bolt pattern into his shops 5 axis mill and drilled them out ant then turned the od down on a set of ranger rotors to make it fit it was free for him but if you dont have a machine shop at hand maybe mark seven stuff??
ranger rotors and two drivers side ranger axles.
83-88 4 cylinder rotors. You may have to do a bearing & race swap also but you have the parts coming off the car. Make sure you use the short rear axle from the ranger. I was told That you needed to use the right axle but my sorce may be wrong.
