I believe my pilot bearing is dying in my car. Ill have it apart Friday to be sure. I was recommended to go with a solid bearing? I'm having trouble finding one.. Should I replace the throw out bearing as well??
Car is being launched around 5K on slicks, fyi.
Yeah, I'll probably re-do a throw out bearing .. again. Not sure why my Pilot bearing is dying.. I found a Pilot bushing .. Kevlar style, at advance auto parts .. I may pick that up??
Pilot bearings go bad from lack off lube or misalignment. When they go bad they usally take out the input shaft with it.
A bearing is going to take a lot more thrust load than any bushing. I don't recommend switching away from a bearing. (in performance applications you always try to switch TO a bearing from a bushing)
The bearing itself has a seal, to retain grease/lube. Make sure its installed correctly and lubricated.
Proper procedure for aligning a bellhousing to the block instructions can be found on YouTube. http://www.youtube.com/watch?v=9Woh-fS3DJA
My brother and I did tighten the bellhousing bolts last night.. at least half a turn .. :S.
I'll have it apart here soon, then see what I want to do.. :s
