429/460 parts
fastford
Offenhauser 429/460 6060DP Dual Port aluminum 4 barrel intake manifold. Purchased new years ago and never used. $250
Sealed Power 224-41139 standard volume oil pump, new in box $25
FelPro 1231 429/460 CJ/SCG intake gaskets, new $15
FelPro 1419 429/460 exhaust gaskets $15
Federal Mogul 260-4005 429/460 intake valley pan, new in box $20
Mr Gasket 390/428 and 429/460 timing tape $5
429/460 head bolts, nice shape $25
Mccord VG 6875M-1 Head gasket kit $50
Mccord 9431 exhaust gaskets (embossed steel) $15
429/460 front cover. One fuel pump bolt hole was stripped and repaired poorly so I had it welded up. Needs one hole drilled and tapped. $25
D1AF-12127-NA Dual Point distributor, with vacuum advance 71 429 4V,CJ, SCJ with auto trans $250
