419” SB2.2 ROX Complete Engine – 4.5 Bore Space MBE Heads and Manifold- Best of the Best
mayhem
Posting for a friend....
419” SB2.2 ROX – 4.5 Bore Space MBE Heads and Manifold- Best of the Best
Awesome N/A Grudge or Class Engine built by Dewild Motorsports
419” SB2.2 4.5 Bore Space Killer Piece
MBE Heads and Custom Cast Manifold – Heads flow 480+ 2.310 intake valve
GM Block splayed lifter package
60 mm Comp Cam
Gibtec Pistons
Total Seal Rings
Jesel Keyway Lifters
T and D Rockers
Coated Victory Titanium Valves
Winberg Crank
MGP Aluminum Rods
Dailey Wet Sump Pump
Jesel belt drive and front Drive Distributor
I have a HRE sheetmetal intake and another cast manifold included.
No Carb Included.
Best of the Best.. Never Dyno’d . Only 10 passes on the combo period.
Ran 7.97 first time out at 2700lbs and a glide
Call or Text Mike (519)718-0545
$26K
Engine is currently at Roush Competition Engines in Detroit.
Own the baddest Small Block Around...
