RED89GTAWSU
New Craigslist add with updated list and a few new parts!
http://detroit.craigslist.org/wyn/pts/1326834519.html
These parts all came off an 89 Pontiac Firebird Trans Am GTA with 12x,xxx miles….one rear quarter was dented up and the motor blew, decided to part out. All parts have been stored in garage away from floor and mostly in sealed boxes and/or covered. I will not ship some of the bigger items…..please email if you need anything shipped and I’ll let you know if I will or if we can maybe meet halfway.
Vehicle below is the door car….
PICS OF SPECIFIC AVAILABLE ON REQUEST
Please use email as point of contact….. [email protected]
NEWLY ADDED AT BOTTOM!!!!
GTA Honeycomb style Rims….Gold w/ crome lip - $500 OBO
T-tops + leather t-top bag…..Excellent condition, didn’t leak when removed - $150
MINT rear seats! $100 for everything
Repairable front seats - $50 for both
TPI L98 Serpentine belt brackets….has altenator, power steering pump, smog pump, belt and tensioner - $100 w/ accersories or $75 bare
Carpet TAN….decent, daily driver or weekend car - $75
FULL Tan interior plastic…..decent, daily driver or weekend car - $75 for all…..might piece out if not enough interest in full set
Full set of seat belts….TAN… - $50
TPI L98 Trans Am Intake elbow from TB to airbox NO MAF - $30
WS6 Springs….120k but did not sag or sway at all….good condition - $50
GTA door panels….TAN, perfect condition - $25 each
L98 Iron Manifolds - $30
Stock Y-pipe w/ straight pipe in place of cat….fall flange on exhaust/catback connection - $25
Short Ratio GTA steering box/gear - $50
Stock Torque Arm -$35
Used 700R4….12x,xxx miles, shifted firm with no slipping when removed - $75
PERFORMANCE SUSPENSION labeled dash trim - $25
Misc. dash/radio trim - $5-20 depending on size
Dash core….NO PAD - $25
Heater box with heater core….all doors and heater core held pressure when removed - $25
Automatic shifter and shifter cable….BLACK nob - $30
Automatic Brake pedal assembly - $30
ACCEL TPI Distributor - $30
GTA body harness and rear tail light harness….minus door harness….fully intact - $25
“FIREBIRD” rear splash guards - $10
GTA rear tail light Center section - $30
DRIVERSIDE rear tail light….GTA honeycomb - $25
Various Roller Cam parts….spider holdown, push rods, lifters, and guides - $15 for everything
TPI Fuel rail with flex hose - $50
NEW ADDS!!!!
Stock Airbox w/mount plate and bolts - $20
K&N for stock Airbox - $15
Steering Column with GTA wheel…..minus radio controls…..radio controls available above - $35
HARD COOLANT LINE…..for oil cooler car, the one that runs down the frame rail on the passenger side, from the radiator to heater core with t off for oil cooler - $15
NEW ADDS!!!!
