90SuperchargedLx
Plugs are wet after cranking and no still no start at WOT, but thanks for the ideas. I'm thinking a ground too but to chase one down would be like finding a needle in a hay stack![]()
Put fresh plugs in gap them and hold it to the floor before u even turn on key on then crank it it should fire check the ground strap from the head to body on driver side also check ground from the block to battery my car had a similar issue and it was the ground from battery to block.
