302 Ford Engine complete
fastford
New build
Roller block with ARP main studs
Mahle dome pistons (10.8:1 CR)
Scat I-beam rods
Total Seal rings
Clevite77 bearings
SFI balancer
SFI flywheel
Balanced rotating assembly
Comp Cams 224/232 @.050" .560" lift HR cam
Flo Tek aluminum heads
ARP head studs
PRW roller rockers
Edelbrock Performer RPM Air Gap intake
Fox body oil pan
Std rotation water pump
Fabricated aluminum valve covers
MSD distributor & Blaster II coil
Shorty headers
12 miles on the engine. Pulled out 4/29/18
$4000 Complete. Drop in and go.
I also have a built C4 that is behind it
