RSpencer
Bought this new in 2015. Just picked it back up from Legend as they performed some warranty work on the siding (added extra screws, common issue). Has about ~2000 miles on it. 15" aluminum wheels. All LED lighting. 5200 lb axles. 4 d rings inside and I believe 8 ft of E track on both sides of the floor. I've mounted a paper towel rack, oil rack, chair rack and a couple other things inside I used this for hauling UTVs/quads. Couple oil stains on the floor, wood on the ramp has a spot that I had to fill because an exhaust pipe rubbed against it for a couple hundred miles, right side of trailer has a scrape above the door from a tree branch. Tows great. No longer need a trailer of this size. $6500
