2008 Cobalt 2.2L help
RSWANNABE
I bought a Cobalt taking a gamble.
The previous owner thought it had the normal timing chain issue, but not a broken timing chain. He replaced it and it still had a noise issue so he decided to sell it.
I bought it, towed it home jump started it because there was no battery in it so I could hear the noise and start to plan what to do next.
It doesn't sound like a rattle as much as I would think, but a knock, sounds like its up high and someone tapping on the valve cover with a ball end of a hammer.
Any thoughts or guesses on this? I'm not familiar with these motors or their problems and was only trying to get a back and forth to work car out of it.
I'm in Roseville in case any of you guys are willing and familiar enough to stop by listen and diagnose this thing with me.
Thanks a bunch in advance
I'd pull the cover and turn it over by hand to look at valves opening and closing (monitor rise/fall distance) to see that one or more aren't bent. It could also be a loose chain guide resonating noise to the cam cover.
how's the oil looking? Does it have a glitter to it? Knock very consistent with rpm? Oil pressure low?
Ok makes sense on all points
oil looks good, but it looks like it was just changed recently too. Knock is consistent with RPM, not sure on the oil pressure, I'll look next time I start it up.
If the knock is consistent with RPM it's most likely bottom end. Possibly piston slap. If it were much faster than RPM I'd look towards valvetrain. Try a cold dry compression/warmed/ wet (if needed) compression check. How is your pressure?
I'll double check the rpm to knock ratio, my answer was probably not the best for the question and I see that. I meant its consistent at low rpm, not varying all over. I didn't rev or increase the rpm to see what happens.
Something else to check is engine driven accessories. A broken spring g on the tensioner or pulley out of alignment and belt smack can make a similar noise.
Ok... Procrastinator that I am I've done some work.
I removed the belt, no difference.
I pulled the valve cover and even though the timing chain had just been replaced the chain was a bit loose. So I put a new tensioner in the chain tightened right up but the noise is still there.
I had it running and pulled coil packs to see if the noise went away, thinking like a rod bearing. I didn't notice a difference except running rough as expected.
Here's a vid please see if you can help me out. I appreciate the input so far.
https://photos.app.goo.gl/vzY2RaKuqiumgRLp7
Also to throw this out there, if anyone is willing to look at this and fix it I'd be glad to pay for your effort.
