Bottlefedford
2001 Ford Mustang GT Roush Stage 2
51,XXX Original Miles
Terminator engine swap from a 2003 Cobra
T-56 Swap from a 2003 Cobra
_________________________________________________
All work and tuning has been done by Kurgan Motorsports
I was told by P.O that the engine has been built and it has cams installed, I do not have proof of this but the car does sound like it has cams / does not sound like the stock 03/04 cams.. Everything else that the P.O has told me adds up but I will be selling this car as a stock engine car to eliminate confusion
Only issues with the car is a header leak on the passenger side head/header gasket and the car idles high (1100-1500rpm) due to the single plate Accufab "Very common with these TB's"
Top is in good condition as well as the paint/body, It has a OEM 03/04 Cobra hood with vinyl carbon fiber in the center - I was going to peel off the vinyl but there is black paint under it so I left it.. It doesn't look bad, Just not my style.
Other Mods:
Kenne Bell 2.4
Kenne Bell Boost-A-Pump
Accufab single plate throttle body
JLT Carbon fiber CAI
LFP Heat exchanger
Acceleronics siemens deka 72# low impedance injectors
Acceleronics VersaFueler
Diablo MAFia
SCT Handheld Tuner
BBK Long tubes
BBK O/R H-pipe
Magnaflow Side exit exhaust
FMS Aluminum driveshaft
2003 Cobra working gauge cluster
AEM Uego wideband O2 gauge
Autometer mechanical boost gauge
Maximum motorsports caster / camber plates
OEM 03/04 Bilstein struts
Aftermarket lowering springs - unknown brand
Aftermarket rear control arms - unknown brand
Huge front sway bar - Eibach
CCV/CC Mod
Spec Clutch - Like new, Very Stiff and holds great
Steeda Tri-Ax shifter
Drilled/Slotted Rotors
Goodridge steel braided brake lines
Nitto NT05R Drag Radials Rears
Nitto NT555 Extreme fronts
03/04 Cd player and trim
Its currently running a 600whp pump tune from KMS
There is much more done to the car but this list is off the top of my head, This car is Extremly fast and very fun to drive.. Im just looking to sell this to buy a 03/04 Cobra hardtop, Willing to trade up to one plus cash on my end.
16,000.00 O.B.O
Other Mods:
Kenne Bell 2.4
LFP Heat exchanger
Diablo MAFia
SCT Handheld Tuner
BBK Long tubes
BBK O/R H-pipe
CCV/CC Mod
16,000.00 O.B.O
