2001 34' fire damaged RV $3,000 Runs and Drives great....Project
NBFRC
2001 34' fire damaged RV $2500 Runs and Drives great....Project
$2500
248-619-6323
15k miles!
Sold off interior parts this weekend. Slideout hydraulics, awning, & leveling jacks still installed. NOthing else left interior wise (no Generator, no AC....etc)
NO ROOF on the RV only 2x3's going across to keep it in tact. RV IS NOT WORTH PUTTING BACK TOGETHER, BEING SOLD AS A PARTS DONOR. It is essentially a running Driving Ford F53 Chassis (Based on F450/F550).
Selling off for the drivetrain and scrap value of the frame. Ford v10, Dana 80, 15k Miles. Runs and drives great! Computer, AC Radiator Fuse Panel its all there.
248-619-6323.
Looks like potential to be a great toy hauler!
Atv's motorcycles etc...
Definitely, and if it helps any I have a set of 42" wide fiberglass doors which were removed from a transit bus. They could be fitted into on of the sides to make loading and loading bikes or sleds. Ill throw these in with the sale at no cost.
big fold up door with 2 ramps and i driving my truck in that bitch and going to the track.
Here is the chassis info...figure out the ramps and this beast will support it!
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 3FC
Assembly Country: MEXICO
Make: Ford
Body Style: Motor Home
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: N
GVWR Range: 19,501 - 26,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: F53
Vehicle Line: F-550
Series: Super Duty Stripped Chassis
Vehicle Type: Truck
Engine Type - 8th Position
VIN Code: S
Cylinders: 10
Fuel: Gasoline
Engine Manufacturer: FORD
Model Year - 10th Position
VIN Code: Y
Model Year: 2000
Assembly Plant - 11th Position
VIN Code: J
Assembly Plant: IMMSA, NUEVO LEON
Production Sequence Number - 12th - 17th
VIN Code: A07293
Prod Sequence Number A07293
Additional Information
Wheel Axles Wheelbase 406.0
