1998 F150 light issue
mrvids
The turn signals and four way flashers work, but the turn signals/flashers on the dashboard do not work. I can hear the sound coming from the relay.
Is it the flasher relay, or just an odd coindence that both dashboard lights went out? All the other lights on the dash seem to work. I tried to get to the relay to swap it but it's is not where it's supposed to be (according to the Youtube videos). The wires have been moved under the dash because of the remote starter that was installed.
I'm assuming tilt wheel? Pop the cover off and check out where the multifunction switch harness connects, my guess is you've got a loose wire there.
agreed, leave the connecter in the MFS and tug on each wire, will likely pull out
