Roller: the is no motor or trans in the car, but the interior is complete and CLEAN, the dash and all the pieces are probably some of the nicest i have come across(no cracks) since this is a 97 it has the upgraded ls1 interior(looks way better imo) has a aftermarket cd player with direct ipod plug in, car has been both 6 speed(stock) and has the auto stuff in it now but could be converted back super easy. actually have the motor harness with the 6 speed stuff still on it and 4l60e stuff too. the ram air hood was just put on last summer,bought it brand new from Harwood. there are 2 small bubbles in the snorkel area that most people will not see, but just wanted to be clear on the description. the whole bottom of the car was painted gloss black with a heavy duty tractor enamel. the engine bay was sprayed with gloss black single stage(i think) car paint, engine bay looks awesome! the car still has all the stock fuel lines but i pulled out and sold the 255 pump(so you could wire another one up and be all set) the rear end in the car is a 1 of 1 set up.. its a ford 8.8(narrowed 2 inches per side compared to our stock rear ends) so this way you have that deep dish wheel it has Toms Kick Ass 31 spline axles in it along with a newer(less than 2k miles) EATON posi with carbon clutches ect. it has a ford racing 4.10 gear in it now(less than 2k also) this rear end is super stout and planned on running it with my turbo set up(over 700 whp) now the interesting part.. it has a 1 of 1 Triangulated 4 link that was fabricated by a close friend(engineer/fabricator) every part on the rear is adjustable but is set up like a fox body would have been set up(since this rear came out of a fox) i have never had it too the track but after 2k miles on the street it was awesome! takes bumps awesome and has a lot of tune ability and has never skipped a beat. the rear also has a UMI drag bar/arb less than 2k also. Rear lca are nice Powdercoated chromoly with rod ends. All the rod ends on the rear are heavy duty4130 Chromoly Steel Heat Treated Injection Molded Teflon Kevlar
from QS Components. These were a lot of money. I have seen these 8.8s in fox bodies go stupid fast, so I am not worried about this thing breaking.
Here are some BRAND NEW parts on the roller.
PA front end kit(chromoly turbo k member, pinto manual rack lt1 motor mounts ect) sphon bolt kit for the front end as well.. new ball joints, wheel bearings, bump steer ect. this is a BRAND NEW front end now.
aerospace components pro STREET drilled and slotted brakes. http://shop.aerospacecomponents.com/...ohatvrdsp.aspx
QA1 R Series 18 way Front coil overs with 300 lb springs and needle bearing and spanners!! and rear Qa1 18 way adjustable too!
everything has been powdercoated on this front end and looks AMAZING!! and light!
the car has mickey thompsons on all 4 corners.(295/50/15 and the radial skinnies on the front with the flame tread) the tires still have a ton of tread left. the rims are the billet specialties street lites 15x10 in the rear with a 5.5 bs and 15x4 front. the rims are perfect!! i took very good care of these.
pics of front suspension and rear. If someone doesn't want all the nice tubular front suspension and brakes for $6800 i can throw the stock front suspension in it(brakes and all) and then the price for the roller will be $4000. this truly is a BEAUTIFUL Lt1 car. there are not too many left out there. the car is located in MI and i can help deliver also.and in the market for a new dd so if you have something you think would be worth my time to trade I will entertain trades.
