sho_off
****I am posting for a friend of mine, not my car but please contact me for more info
CAR IS LOCATED IN WINDSOR, ONTARIO, CLEAN TITLE.
1982 ZEPHYR. IT HAS A 302, WITH A 5 SPD.
-ALL MSD IGNITION
-PRO STARS ALL THE WAY AROUND
-GREASEABLE BBK REAR UPPER CONTROL ARM'S, MEGA BITE SENIOR'S IN THE BOTTOM
-4:10 RICHMOND GEAR'S. BUILT BY BY A PROFESSIONAL. CARBON FIBRE CLUTCH'S, ALL NEW BEARING'S AS WELL.
-3.00" WHEEL STUD'S BY MOROSO
-DUAL ELECTRIC FAN'S
-FULL LENGTH HEADER'S WITH AN X PIPE GOING INTO SINGLE CHAMBER FLOW MASTER'S, WITH FLOW MASTER TAIL'S
-FRAME IS TIED THRU THE FLOOR WITH 2"X 2" BOX STEEL. I PUT IN HOME MADE BATTLE BOX'S FOR THE TORQUE BOX'S
-IT HAS AN EDELBROK RPM PERFORMER INTAKE WITH A 670 HOLLEY STREET AVENGER CARB
-DUAL SNORKEL AIR CLEANER WITH A K & N FILTER. ALSO HAS THE TUBE'S IN THE FENDER WELL'S FOR RAM AIR
-NEW BRAKE'S ALL AROUND WITH 5 BOLT FRONT & REAR
IT ONLY WEIGH'S 2900LBS. I PUT MOST EVERYTHING FROM A 1990 5 LITER IN IT. REAR END, STRUTS, ENGINE CROSS MEMBER, AND PEDAL'S. IT HAS BEAUTIFUL RED INTERIOR, PRETTY MUCH FLAWLESS. THE STEERING WHEEL IS CRACKED A LITTLE. THE UNDERNEATH IS PAINTED SILVER, IT HAS NOT ONE HOLE ANYWHERE. THE HEAD'S AND CAM ARE FROM A 94 GT 5.0 WITH AROUND 25000 KMS, AND THE MOTOR IS AN 89 5.0 WITH ROUGHLY 170XXX ON IT, ALONG WITH THE 5 SPD TRANS. ALL THE GLASS IS VERY GOOD AND CLEAR, NO CHIP'S.
$7500.00 O.B.O, THIS CAR IS ONE OF THE CLEANEST YOU WILL ENCOUNTER. NO LOW BALLER'S, BUT IT IS NEGOTIABLE.
-ALL MSD IGNITION
